It is currently Fri Jul 25, 2025 8:22 pm
PostPosted: Mon Apr 28, 2008 1:28 am
Does anyone know who distributes these?
It's a 200 watt Vulcan Cartridge Heater from an Ibex bending iron which had an unfortunate tumble and no longer works.
I can't find a distributor in Australia and I'm having trouble Googling for any distributors in the States.
I can find the Vulcanco website but there's no pointers to retailers on that either.
Bob
Bob Connor
Geelong, Australia
PostPosted: Mon Apr 28, 2008 2:33 am
I know I can get them from LMI but I'd like to see if I can get them cheaper elsewhere.
Bob
Bob Connor
Geelong, Australia
PostPosted: Mon Apr 28, 2008 6:27 am
try Omega .. they make heaters in all shapes and sizes.
PostPosted: Mon Apr 28, 2008 10:02 am
SPBPS-EL Replacement heating element, 110 volt In Stock $30.75
This is from LMII.com
What voltage are you using there in Australia?
SPBPS-EL220 Replacement heating element, 220 volt (International) In Stock $30.75
You already spotted these, I'm sure. They have both.
PostPosted: Mon Apr 28, 2008 11:50 am
I don't know where the Vulcan brand comes from, but I would bet Watlow makes one that would be a drop in replacement. I believe they make the "Fire Rod" cartridges, which may be a bit more widely distributed and easier to find. I use them for a number of miscellaneous heaters.
PostPosted: Mon Apr 28, 2008 2:54 pm
Here you go.
http://www.aussieweb.com.au/map.aspx?id=2058171
If you have the dimensions and wattage, I'm sure Watlow has a FireRod cartridge that will directly replace the Vulcan one. I've used Watlow cartridges and silicone heaters for years and they have always been great.
PostPosted: Mon Apr 28, 2008 4:37 pm
Thanks gents.
I've just had a look at the Watlow catalogue and it looks like
they'll have one that's suitable. Thanks David.
Bob
Bob Connor
Geelong, Australia
